How fast does 0170-6C rust?
calyth
#!/bin/sh of a man
The question is in the subject...
I won't be able to wear my CQB3 that often, so I would like to know how fast the edges on a 0170-6C would rust. I live in BC, Canada, so I think the weather would play a good part in this.
It will readily rust in hours if you don't dry it off. Just clean and dry it after use, and wipe with an oily rag between uses and it should never be a problem. How do you like that knife, balance etc.?
The knife is great, the only two grips is that the thumb serrations on the spine doesn't quite work, and probably someone drilled the holes on the tang for the handle pins a bit too large, and the handle slabs moves.
The blade is the sharpest I've seen other than the Frost Moras. It's one of the sharpest blades. I got a piece of leather that so far, only Spyderco in 440V, the Mora, and the CQB3 could cut quite easily. Even the Spyderco VG10 blades tkae some effort to cut it.
