When I first started collecting knives, I was focused on small, high-quality folders, such as the Spyderco Cricket, Michael Walker, or the Benchmade 330 Pardue. Then I ran across the Spyderco Military. I then got hooked on bigger knives. I then purchased many linerlock knives in the 3-4 inch blade size. After starting to use them, mostly the Military, I quickly found out that one can simply squeeze their grip on the handle and easily unlock the linerlock. This was not so easy for all of them, but in conjunction with the amount of blade play in over 85% of my linerlocks, I became very disgruntled. This led me on to a quest for the perfect lock, something other than a linerlock, and something that had ZERO blade play in any direction. I have tried the Microtech Micro Bar, the Rolling lock, the Compression lock, and the Axis lock, but I have really focused on the Axis (too much blade play in the other ones, except the Micro Bar, but I have heard some bad things about it failing the whack test). Once I found a reliable lock, I then began focusing on a guard on the handle, one that would prevent ones hand from sliding up on the blade when stabbing something. These are few and far between. I have had to resort back to the mini AFCK and the Microtech Kestrel, both of which are great knives, but I still desire a much stronger, secure, solid, no-play lockup. I knife such as the Kershaw Boa would be my Ultimate knife if it had an Axis lock and no speed safe assisted opening (it breaks after about a thousand openings). It has the perfect length blade, a great shape with plenty of belly, and an excellent hand guard as part of the blade.
I have searched now for over 2 years for what I call the perfect knife, but I am still looking. I am wary of going to a custom knife maker, as many of the customs I have tested fail the ZERO blade play test.
How have your knife requirements evolved over time?
