- Apr 5, 2000
This certainly has been done before. I think Bradshaw took the wind out of my sails with his bowie-in-process pics, but I figured I post these anyway.
This knife started out as a 1.25x.25 bar of 1065. First step is forging. This wasn't my best forging, I'll explain later, but it is decent. There is a little more scale on this than I like, I should have turned the forge down a little. Sometimes I like to forge in the swedges, but I wasn't brave enough with this one.
Next step is profiling. The blade goes on the belt grinder with a 36 grit belt. I profile the blade and rough out the tang and square the shoulders.
Next step is rough grinding. I take the blade from 36 grit to 80 grit. At this point the blade is pretty close to the final dimensions. More material will be removed in a later step.
The blade is then stamped and the shoulders have been filed in using a file guide. This phase is the quench. The blade is brought up to heat then quenched in oil. I always do this at night so I can accuratly judge the color/temperature of the steel. This is what the blade looks like right out of the quench.
Here's a little better shot, also with the swedge outlined.
