How is the Spydie Para-Military for carry?
I really like my Delica but Im a liner lock /G-10 guy and the Digi-Camo Para is calling to me. Is it as good a slicer as the Delica?
Ha, it blows the delica right out of the water when it comes to slicing :D
You're gonna get pummeled with rocks for that one :p
The para is a much more "substantial" knife than the Delica. I think it cuts just as good or better than the Delica and would easily be my choice if I had to choose between them. The only down side is that if I remember right, my Para is tip down only.
I have the Foliage Green G10 Delica. The blade grind is thin and it sharpens up to a hair splitting edge. Its VG-10
the para military is pretty much superior to the delica, and the compression lock is great. i prefer the caly3 though
Ah, then they should be about even, but I would still give the tossup to the para-military. Excellent grip, carries light, and performs like a big knife. I miss mine :(
I had the standard S30V black handle version for a short amount of time, but it really grew on me. The compression lock will be a tad different from what you are used to, but it flicks closed with a little practice.
So its not a liner lock?
Oh no, it's even better :thumbup: It's similar in action, it's just placed on top of the knife instead of where your index finger goes. By some ways of mathematics and Spyderco's awsomeness, this makes it a VERY strong lock.
Typically I've heard of people pinching the lock with their index finger and sort of using gravity to flick it closed. It takes a try or two, but it's fun once you get used to it.
I hope that helps, J.
I just looked at some Youtube footage. As long as the blade swings free enough to do one hand open and close Im cool with it.
I have a D2 para as well as several different versions of the D4 delica. The delica has a better handle to blade length ratio than the para but the extra hand on the para really fills the hand nicely and feels very secure. I like the para a lot, but the lock took some time to get used to, but now that I know how to operate the lock its very smooth and very comfortable to use. There is no way of doing it left handed, so if that is a concern. The only other gripe that I have about the para is that it is tip down carry only unless you have some one like STR do a custom job on it.
The Delica is a child's toy compared to the Para Military. :D Para > all
Welcome to the forums, Para Power!
So let me get this right - you like the Para-Military? :p
I am just messing with ya. I have 4 Para-Millies myself. ;)
Thanks for the warm welcome. :)
Honestly I don't think I've ever seen a knife that I didn't like. I just like some more than others.
I do want to make sure the OP understands that the Para is no ordinary cutting tool. It is a precision instrument designed by and for professionals so he needs to understand this before taking on the responsibility of owning one. :cool:
The biggest difference between the two is the blade geometry. The Para is a Full Flat Grind and the Delica is a Flat Saber Ground. The Para is a "Slicer" and the Delica has a thicker "Utility" blade.
For around $30.00 send it to STR to get a deep carry/tip up.
G10 Delica has 2.5 mm thick blade and Para has 4mm. This Delica must slice better due to the blade geometry.
+1 Caly3 is the best (3mm thick FFG blade, low riding wire clip, finger choil), Native4 is not bad either.
I think it's one of the easiest knives to open/close one-handed. Easier than frame/linerlock for sure. When you disengage the lock with your index finger, none of your fingers are in the blade's path when it closes.
I have several Paras and several Delicas. IMAO, the Para wins every category except weight/size. It's a tad heavier and thicker than the D4 FRN, but it is a much better slicer, it's easier for me to sharpen and maintain, and I really prefer TD carry. It rides very well IWB and pretty good in your pocket, too.
And you can get it in D2 which I really like.
A little smaller than the Military, it's handier and if anything stronger due to it's superior lock. It's a great size to clip in your pocket and gives up very little compared to many bigger heavier knives.
[/IMG]
