how long does it take
Hello everyone, I was wondering to all the slip joint makers how long does it take for you to complete a typical knife from start to finish, I have made slip joints of and on for a few years and each one is different as far as time required, I probable have 40 hrs (strictly as guess), I just work on them when time allows. I was wondering how long it takes the pros to complete a knife.
thanks
For efficiency It’s best to do them in batches. Any operation, the first one takes “x” amount of time. The second one takes 1/2 as long and each one thereafter takes 1/4 as long.
And as always the details matter. How complex are the liners , scales and pivot fittings? etc etc
When I took a class on a slipjoint, we did it in less than two full days.
I stopped making them but I’ll get back into it eventually. They take from 2-4 days depending on the complexity and batch size.
I didn’t do the engraving on these two. But these are integral bolsters liners combo with radius and forged blades. These take awhile.
HSC: Those are NICE looking slipjoints. How is the pivot handled with the screw? It looks good. Your curved bolster/scale joint looks good - I've been wanting to try a radius joint that is dovetailed also, but haven't had the nerve to try..... yet. Good job.
To the OP's question of how long - I don't really like to think of how many hours I put into a slipjoint. For sure more than a chef knife :)
You have to be far more specific for an accurate answer
...When I took a class on a slipjoint, we did it in less than two full days...
Did that include heat treating time? Heat treating alone takes me most of a day with two tempering cycles.
I am certainly not the "pro" you are looking for answers from, but my early slipjoints after the first one or two took me about 12-15 hours (not including heat treat sit around time) by working in the evenings after kids went to bed and during kid's naps on weekends. Now that I have gotten better, they take significantly longer (double-ish?) because I spend more time on the bevel grinding and finishing. I have never devoted a full couple days to making one to see how fast I could go with contiguous effort. It sounds like fun though!
Come to think of it, I also have mandatory 24 waits while epoxy cures. All these waits suite the intermittent time periods I have to work, but I don't think I could make one in a single 48 hour period using my normal processes.
thanks everyone for the replies, I work part time making knives as a hobby, and I was curious if the amount of time I spend on a knife is average or below., I know it was a vague question and the more embellishment you do requires more time, HSC where did you take a class at? I have learned everything via videos and trial and error. I really enjoy knife making and do everything in my shop including heat treat,
Yes. You can flash temper as needed. Which just takes a few minutes
Mike Vagnino ABS MS in Visalia CA
The pivot is a precision barrel bushing that’s internally threaded.
thanks HSC, that is a little far for me I'm in Ky lol,
can someone give an example/explanation of flash temper?
thanks
thanks
It’s a torch temper or tempering on coals. Just a quick way to temper a blade, it can take a decent amount of practice to get right or good at it. Typically it involves either watching the color of the steel turn to a specific color like light straw or medium brown or slight purple depending on desired hardness by heating with a torch or doing the same process with a torch but using tempstiks to see when the entire blades reached an even temperature based off the tempstiks melting
