- Sep 5, 2009
I don't have a belt grinder, and don't really want to drop the money on one. Do any of you guys just use a bench grinder? What else do you use if you don't have a belt grinder?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Angle Grinder and HF Belt Sander are pretty cheap and work. I "used" (I say used, because I'm getting a band saw) a very nice Bosch angle grinder with Norton cut-off wheels. When I needed to cut a radius, I'd cut a bunch of "teeth", like a comb has, around the radius. Then, cut the teeth off around the radius. Then, switch to a grinding wheel and grind the teeth down to my scribed line in the Dykem coated blank. I've become very good at cutting out a smooth radiused blank with this method because it's all I had. I would then use the HF belt sander to clean up the profile, and if I needed a tight radius, say for an index finger groove, I'd use sanding drums chucked in a drill press.
+1 except I use a dremel or hand files for the tight spots.
You definately need a respirator when using an angle grinder though. Mine kicks up enough dust and fumes to set off the smoke alarm just off the garage in the house when I open the door.
Well, with the angle grinder, I'd end up totally destroying the knife because of the kickback. I'm not very precise with that thing
I really like the drill press idea though... might try that tomorrow.
