- Sep 16, 2005
Another question, I have a spyderco sharpmaker I also have a S30V hollow ground blade with good heat treat that I'm sharpening for first time. I didn't let it get too dull but unless I'm doing something wrong sharpening that thing is a bear. About how many passess should it take on the sharpmaker sticks to get the thing back to factory sharp as it came REAL sharp from the factory. I've been able to get it back somewhat but just not like it was from the factory, it would shave arm hair from the factory, I can't get it back to that point. It got dull on some plastic used for six pack rings and so I resharpened afterward I had to cut up some cardboard boxes and it did better so I know I did something right but I still can't push cut the edge of a sheet of comp paper. I can use a very slight slicing motion to get it started and its like butter, but just starting from a standstill and trying to get a smooth clean cut, and it just tears or rips the paper. I worked on it again this evening and got it push cut the comp paper about 4 or 5 times and then it went back to requiring a slight slicing motion to get it started.
I used the grey sticks and then the white with pointed side then flat and pointed side then flat for 20 passes each stick just like the manual said, but it still aint shaving sharp. Is it me, is it S30V, it is the sharpmaker, help this is my first go round with S30V.
Thanks
Thanks
