How much effort for the speedsafe
Hey guys im kinda debating between two kershaws, the mini cyclone or the leek
and im wondering how much effort is actually needed for the flipper or the assisted opening to engage.
My main concern is that if i bump into something or something strikes my pocket with enough force that it will deploy the blade. Its either that i lose my pair of pants or i get a bite from the puppy.
I have a couple of Speed Bumps and a Shallot, and enough effort is required that I'm confident they won't open up on me accidentally.
I have several of the leek variants as well as a mini cyclone and in my opinion, the speedsafe on both are a perfect combination of very little pressure to open and just enough to keep it closed in the pocket. I have been carrying a kershaw speedsafe knife almost daily for about a year now, and have never had one open accidently.:thumbup:
If you are concerned with one opening in your pocket, the leek has a lock that can keep the blade closed and the cyclone can be switched to a manual opener, so no speedsafe to worry about. But you should be fine, its a Kershaw;):thumbup:
Oh, and let us know which ones(plural for a reason;)) you get!!
I've been carrying a Leek off and on (mostly on) since they came out.
I never use the safety and have never had it open in my pocket.
I'm not saying it can't or won't happen, but it's never happened to
me. I don't have a MC but from what the other guys have said, you
shouldn't have anything to worry about with either of the two.
wow and hearing all those stories(maybe over exageration) about how they tore out this guys pockets and how unreliable speedsafe is, i dont know now..its hard to choose between the mini cyclone or the leek
I like the leek for its profile but afraid it might be too small
i like the mini cyclone for its shape, but the speedsafe switch is only effective when the knife is opened.
Do you live close to some place that carries either?
Wally world usually has the Leeks in stock.
YN, I don't know where you've heard these things, but I've been hanging around here since the beginning of the Kershaw sub, a little over a year ago, and this is the first I've heard of it!
As mentioned, the Leek has a safety. I've got all of mine tightened down in the off position. It's irritating to me to go to open the blade, only to find out the safety bar has slid over to the locked position.
Here's another thing to consider. When set for tip-up carry, the Cyclone, if you keep it in the far right of your right front pocket, positions the blade is up against the pocket seam. This is true for any knife that offers tip-up carry. I personally like this position, because my index finger naturally falls on the flipper when I reach into my pocket for it. Thumb and third finger knuckle pull the knife out, and my index finger is already on the flipper.
Also, the torsion bar that activates the SpeedSafe also acts as a safety. The same energy that fires the blade is compressed when closed, keeping it in the handle until you start the blade in motion.
As for accidental firing, I've carried Leeks and Cyclones and I've never had a SpeedSafe go off in my pocket. This holds true for any of the SpeedSafe models. Another alternative is to go with a Blur, which has no flipper. Still SpeedSafe, but activated by the thumbstud. Either the Leek or the Cyclone will be a great choice, and I wouldn't be real concerned about having your pants cut up or possibly damaging the boys! Hope this helps!
What stories?
SpeedSafe is unreliable? When did this happen?
those stories are from the dead people who were bad and went to hell and their speedsafes constantly break and open up in their pockets and cut their junk off.
up here we are all good :)
If they were in Hell, I doubt that they would have Kershaw SpeedSafe knives, more likely chinese knock offs.
Also, I've only ever had one open in a pocket on me, and that was a very loose cargo pocket where the flipper got pressed against some fairly large objects in the pocket.
I've had one torsion bar break in the last 10 years.
I have about 2 dozen Kershaws and none have seen
Kershaws CS department.
Pretty reliable I would have to say. :thumbup:
i've had my leek open in my pocket, but then again i was also bored and playing with it as i couldnt take it out *stupid public*.
OK as true as that is, it is sig worthy, so have fun guys.
oh and YN, dont worry about the horror stories. the MC takes some force, and the leek has the safety
I've had the Speed-Safe since they first came out and the Leek from Feb/2003 -
I wrote a review of that original Leek -
Kershaw/Ken Onion LEEK (pics)
There is a section where I deliberately tried to "accidentally" open the knife, and failed.
I like the Leek enough that I have 6 of them (different versions) -
Kershaw Rainbow Leek - a pictorial review
Black "boron" Leek
G-10 S30V Leek (matte version)
polished G10 S30V Leek
Kershaw Composite Blade Leek
I have basically EDC'd a Leek since Feb/2003 (except for about 1 year when I used the JunkYard Dog) and have not had any Speed-Safe open unintentinally -
EXCEPT one single occassion when I pulled the knife out and dropped it and it opened when it hit the ground - that was well over a year ago.
Here's a photo showing the amount of stand-off of the Leeks, to show how much the blade actually has to be moved before the torsion spring kicks in.
Anyway I have enough confidence in Speed-Safe that I have my at home EDC Composite blade Leek clipped to my pocket right now (with the safety off)
Safety is each person's own responsibility - and it comes down to one's own judgement.
Of course, to be ultra safe the manual safety can be adjusted so that one can operate it with the pinky finger, and so can be engaged while carried .....
Vincent
http://picasaweb.com/UnknownVincent
http://UnknownVincent.Shutterfly.com
http://UnknownVT.Shutterfly.com
http://clik.to/UnknownVincent
