- Nov 2, 2010
I have a KMG grinder. How much pressure should I apply when grinding?
To reduce variables, let's say a flat, primary grind on 1/8" thick, 2" wide blade, using 60 grit orange blaze belt. Running at high speed.
I've seen the phrase "avoid excessive pressure", which is no help. It's hard to see in videos just how hard people are pressing. When Nick Wheeler presses gently, it's probably like me pressing hard.
Push hard enough to - Break a pencil? Anger a cat when petting it? Anger a newfoundland dog?
(The above scale is not ANSI approved... yet)
I'm also under the impression that significant force would cause ceramics to crack and expose new surfaces. Would that then shorten the life of the belt by applying constant, hard force?
