- Feb 26, 2002
I recently purchased a 22 inch Sher made Kobra. I found it better at chopping and cutting two inch to twig size branches around the house than my two 20 inch Sirupatis, and there is quite a bit of work around the yard I can give it in this branch size. It has the exact same spine thickness as one of my Sirupatis and is a quarter of a pound heavier than that sirupati (Sirupati 22.4 ounces, Kobra 26.3 ounces). The Kobra does have a thinner side profile than this Sirupati but has a thicker cutting edge.
However, the opinions of forumites on the Cantina varies greatly when it comes to how much work a Kobra can take. My understanding is that it is the only khukuri that is not covered by the HI warranty. Rusty recently mentioned that a 20 inch Kobra might make an excellent machete replacement, but if you try chopping 2 or 3 inch thick saplings or branches, it will eventually fail. However, Tom Holt believed that the 25 inch Kobra was an excellent all round khukuri. If I remember correctly, he eventually broke his, but only after hitting hidden rocks with it. Raghorn mentioned only a month ago that he regularly used his 18 inch Kobra to clear trail and cut saplings up to four inches in diameter.
I am trying to judge how much use to give my Kobra. My questions are mainly aimed at those who own a 20 inch to 22 inch Kobra: What is its length and weight? How much use had you given it? If you have broken it, how did you do it?
