Sure. I would do it by electric welding. Then forge & grind to shape, dress any mushroom as needed. Then final heat treating will be good as new. About 4-5 hours... Our hot work rate is 125$/hr. Most other shops are similar.Can a backyard blacksmith insert hard steel in any of these old wore out axes?
Can't give you a dollar amount on these forms but I'll tell you that the bit is about 1-1/2" short from wear and if it's an overlaid bid then it's well past the hardenable steel. You may want it for some reason but I would never use that axe.
I concur with this opinion. Brit-made head patterns tend to be longer than n. American and this one has become 'short' even by New World standards. Once you run out of usable blade steel you're left with an ID-stamped paper weight or door stop.Can't give you a dollar amount on these forms but I'll tell you that the bit is about 1-1/2" short from wear and if it's an overlaid bid then it's well past the hardenable steel. You may want it for some reason but I would never use that axe.
I sure don't recognize this kind of cost, but maybe I've just struck gold with the blacksmith I go to. I'm sure of it. Rebuilding of old axes? Without referring to any one axe in particular, I'm all for it and the more the better.Sure. I would do it by electric welding. Then forge & grind to shape, dress any mushroom as needed. Then final heat treating will be good as new. About 4-5 hours... Our hot work rate is 125$/hr. Most other shops are similar.
You sure you want to rebuild old axes ??
