A good sharp edge should be obtainable, even to a beginner in 30 minutes. (At 320 grit.)
HOWEVER
Much will depend on your temperament. Are you patient? Are you even a bit obsessive?
When I was new to the Edge-Pro, it was not uncommon for me to spend an entire evening, i.e. three to four hours on a single blade.
It had to be perfect. It had to push cut telephone book paper in both directions easily. And the bevel had to shine as brightly as a Pink Tape could make it shine.
Of course, there was no necessity for this, but it did wonders for my learning of the machine.
Set the angle by the sharpie method, then use a 120 or 180 stone until tyou get a very pronounced burr on the opposite side. Flip the blade over, grind off the butt, and continue sharpening until you get a burr on the first side.
Change to the next higher grit and repeat. BTW, an angle cube helps greatly in setting angles when changing stones.
I usually stop raising burrs after 320 grit. A 4X magnifying glass and a bright light will let you see the scratch patterns and let you know if you have reached the edge with that stone. Take your time. Use very light pressure, keep your wits about you, and in a very short time your edges will look, and cut, as well as those done by professional sharpeners.
The stones provided with the Edge-Pro are splendid. But you will eventually want to step up to even better stones. I suggest the Shapton Glass Stones from Chef Knives To Go. Buy one or two at a time until you have a set. I should also say that you won't need the 30,000 grit unless you are as truly fanatical as I am!
