- Feb 12, 2001
Well, the bolster on my chiruwa WWII blem was a bit loose, so I decided to try some superglue to tighten it. No luck. It let loose after the first few chops into big walnut stump I use for testing chopping. I then decided to try gently tapping it into a tighter fit with a hammer. Big mistake. It left little crescent-shaped dents in the brass, even through the rag I had wrapped around it. Oh well, the crescent is one of the symbols of Nepal, right?
Anyway, I then heated the bolster with a candle for about 45 seconds or so to try to re-melt the laha, thinking this would eliminate the looseness in the bolster. It didn't work, but I am wondering if this is enough heat to damage the temper of the blade. Anyone know?
Well, finally the problem seems to have pretty much fixed itself when the horn handle slabs expanded a bit after I applied hooflex. Guess I should have tried that in the first place.
So, my two questions to the learned cantina members:
1) Is there a preferred method of fixing a loose bolster?
2) Is the heat of a candle flame on the bolster for a minute or so enough to damage the blade temper? Is there any way to tell if the temper has been affected?
Thanks,
--Josh
Thanks,
--Josh
