How old do you think this 119 bundle is?
To preface, I did try and read through the extensive older thread on 119s but most of the hosted images are long gone and one of the more recent posts were from someone instructing someone else to start a new thread as they bumped a 3 year old thread.
It looks like a 3 spacer knife, not sure if someone could glean a date range from this series of items; knife, sheath, stone, box etc.
Thanks in advance
73/74 to about 77.
The box changed from 2 piece to 1 piece about 1977, that is your top end.
Three line upright starts in 1973, the lower end.
The normal progression was 4 spacers dropping to 3 in 1981 BUT... the 119 and 120 changed to 3 spacers very early on. 3 line 4 spacer (upright) 119's and 120's are very rare but are the most common configuration in all other 100 series knives. Given that, I presume the change to 3 spacers (119,120) happened late 1973 or possibly 1974. Definitely before 1975.
Looks like you have some paperwork. Look to see if there is a printers date code on the lower left corner of the use and care sheet. If you have it, that would give you a "can't be older than" date. Hope this helps. /Roger
so would a 3 line inverted stamp with model number be a 72? if i understand correctly, Buck started butting model numbers on blades in 72.
These 2 models in this configuration are difficult to pin a mfg. Date on.
TAH and others have gone round and round on these. My sheets on these
(admiting the 120 & 119 changed earlier) from the BCCI 20 year say up thru 1980 the guard and pommel will have 2 spacers each. In 1981 'mid' they will have 2 spacers in the pommel and 1 in the guard. I have both these models in my collection and they have the thick convex grind. So, 440c steel. One has the flap sheath, the other a snoopy sheath. Its been argued these are from 1979 - 80. Even earlier. DM
Addendum, the accessories, while they could be contemporary to the knife, do not contribute to determining the age of the package as they were in the Buck catalog thru much of the 70's and 80's.
I remember that dance well, David. I still agree with Roger's timeline above. Plus the flap sheath on the 119 and 120 was discontinued earlier than the other 100 Series knives. I believe the 119/120 swivel sheath was introduced around 1977, which would correspond with Roger's timeline as well.
y'all did real good on dating this one. lots of great info from everyone. learned a lot. thanks to all of ya.
I pulled my catalogs and found the model 136 pictured in the 1985 catalog. Along with both styled sheaths offered. Snoopy & flap. DM
'Swivel sheath' , your saying is the 'snoopy sheath? 1977. DM
I call this style a swivel sheath...
2-buck-119s-1970s-2-different-blade-styles-nice_1_38b0774df2c43f7054852cec69601170.jpg
And this style a Snoopy sheath...
I might be calling them the wrong names. Wouldn't be the first time. :confused:
Did Buck package the honemaster, oil and hard Arkansas stone together in a box as pictured in the OP?
I think your name calling is correct Tom:D
  • Like
Reactions: TAH
Thanks for the vote of confidence, Preston. I often doubt myself, especially when David questions me. I have a great deal of respect for him. :thumbsup:
I am diverting from the OP's question but I'll plow ahead.... do you think the swivel sheath outright replaced the flap sheath or did they coexist thru the 70's? Certainly by '81 the flat sewn sheath became the standard. Interestingly, why was there never a 'flat' sheath for the 103? I know there was one for the 102, 118, 119, 120, and 124.
I am diverting from the OP's question but I'll plow ahead.... do you think the swivel sheath outright replaced the flap sheath or did they coexist thru the 70's? Certainly by '81 the flat sewn sheath became the standard. Interestingly, why was there never a 'flat' sheath for the 103? I know there was one for the 102, 118, 119, and 124.
Good question, Roger. If I had to bet, I'd put my money on the swivel sheath outright replaced the flap sheath. Just makes more sense.
