Fred.Rowe
- May 2, 2004
I posted this in Shop Talk wanting to know what makers think about this. The Custom and Handmade forum is frequented by many collectors and purveyors and I would like to know how you see this as well.
Fred
Each and every knife sold, whether a custom, bench made or factory blade, should be presented to the new owner along with the blades bevel angles and the specific "original" angle at which the edge was sharpened. If the new owner doesn't have this information, how can he select the correct angle to "touch up" the edge when the blade dulls slightly or God forbid, if the blade is chipped, how does the owner chose the angle that "matches" the original.
I think you can assume that the angles that were chosen by the designer/maker of the knife were chosen to compliment the blades geometry and intended use. If this is true then matching the original angles is mandatory. If these "original" numbers aren't reproduced during touch up or resharpening; the new owner could be destroying what the maker of the blade took so much time to create.
Any knife blade can be sharpened; but only to the degree dictated by the blades geometry.
Would you like to know what angles were used to grind and sharpen the blade you are buying? If so let makers know when you purchase a new knife; I'm sure they would be happy to give you this information.
Happy grinding, Fred
Fred
