I love sharp knifes. The sharper the better. My two sharpest knives are my BM 550 and WH Evolution Wharcliffe. The WH came sharp and I made the 550 sharp. Do I have any special skills sharpening? No. I use the sharpmaker and an old belt to strop when done. My knowledge of how sharp a knife can be can be accredited to four things: (add or correct if I'm wrong) 1. type of steel used on blade 2. heat treat 3. primary grind 4. edge grind. But I don't think I really understand the dynamics of a truly sharp edge and what it takes to get one. For example, the BM 550 uses a flat grind and a thin edge and 440C steel. The MT LCC that I used to have also had a flat grind and a thin edge and used 154cm. I could get the edge sharp on the LCC but not as sharp as my BM 550. So, at one point, I sent my LCC back to MT and they sent it back with a screaming sharp edge which was as sharp as my BM 550. So I started thinking my sharpening technique must be in error, BUT how did my 550 turn out so sharp. Ok then, 440C must just take a better edge. But I just said that MT put a great edge on the LCC And what about BG42, the cousin of 154 cm with vanadium added for the purpose of limiting the size of the carbides and thus allowing for a finer=sharper edge. The addition of vanadium to VG-10, which I believe is the cousin to 440C, had the desired results because man is that steel sharp. But then I go back to the fact I can get the Sebby sharp but not as sharp ast the 550. So what I have learned so far about edges in my 3 plus years of buying knives is that: 1. the thinner the edge the sharper 2. I can't get 154cm as sharp as 440C . I can't get my Sebby as sharp as my 550 and it frustrates me because I want my Sebby to be THE sharpest knife I have and it isn't. So what is the point of this misc rambling? I don't know. But I sure wish I haven't become so obsessive about edge sharpness.
