How Thin?
With flat grinds, how thin are your blade edges before heat treat? After heat treat, how thin before convex sharpening grind?
Thanks.
What unit are y'all talking????
0.040 " sounds about right while 0.30 " is bigger than 1/4 " that is alot of hardened metal to remove after heat treat.
ron
I use a propane forge and a 3" pipe with one end sealed when heat treating to reduce scale. I use a magnet to check temp. Until recently all my knives were stock removal. I am working on 4 small knives forged to general shape, then flat grind to final. I got my first distal taper forged today, almost no grinding required.
The routine now using 1095: forge to shape- refine with grinder to 240 finish- 3 heats to stress relieve- edge quench in 150 F canola oil.
Thousandths??? About the width of a dime before heat treat, down to either 120 or 220 grit but I do make sure the ricasso is flat and parallel with calibers. I take it to no less than 220 grit.
Afterward heat treat, as thin as I dare on a 4" drop point hunter, being careful not to overheat on the grinder. I have a water bucket under my platen. If it discolors the least bit the temper is ruined.
Craig
All of my folders are heat treated before grinding. Most of my fixed blades are ground about 70% before heat treat. My normal edge thickness is .010 unless customer asks for something different.
