How to add metal designs to knife scales?
I have some pocket knives I'm repairing (broken scales). Most of them have cracks and missing badges(?), etc., ordinarily I just put scales on without the designs because I had no idea how to make them or put them in the scales. If any of you guys do stuff like that, could you give me some pointers on how to do it? Is it like marquetry or inlay with wood (I have a little bit of experience with that - only with much bigger pieces). How/where do you get the metal silhouettes to put in there?
Leading Edge Fabrication sells a variety of stainless steel knife handle shields and the parser plates to go with them. If you have the patience you can cut your own out from any kind of metal (or any material for that matter). The pre-fabricated ones can save you some time and effort.
Jeff
I have a pantograph milling machine that does that.
Craig Brewer has a service where he puts a shield of your choice in your scales.
He also has templates if you end up getying a pantograph
Unsurprisingly, there was already good information on this forum:
I made my parser plates from Ats-34 by collecting old sheilds and copying them. Traced the sheild onto the steel and jeweler filed out
the cavity. Then made the new sheild by tracing it inside the parser plate. Then I clamped the parser to the mark side of the knife with
the scale in it and routed it out with s dremel bit on my drill press. Works really slick once you get rolling on it.
Ken.
