- Mar 6, 2022
I wracked my brain, and spent way too much time trying to accomplish these tasks that I assume there is a far easier way to do it. So here I ask:
1. Brass rod cut to a little more than necessary length necessary for liner and scale. I countersunk the liner a little (pretty thin to start with) and put the piece of rod in. Then I hit it a few times with the flat face until it stopped moving so easily. Then I commenced to hitting it all around with the round end until it spread out. Not counting the times I missed and cracked the scale material.
In some cases I was able to get the liner side pretty flat, and in some other cases it was still proud. I filed off the proud part, although I think I may have not filed enough off the inside, since I have gaps between my liner and my back spring.
2. Stainless rod. Pretty much tried the same thing. But it was far less cooperative. It also needed to be thinned because the holes I had available in the spring seem to be a bit thinner than the 3/32" stock that I bought. So I put a longer than necessary piece in the drill and spun it against the the disk sander to get a smaller piece. Then I sharpened one end, to be able to "pull" the spring into line for assembly. I should have started longer because by the time I was done on one side I still had the taper in the hole. I was able to sand the pin shorter and it went red. I thought that might help me peen, but it was still very hard to do. Although, missing and hitting the stainless bolster, was much less upsetting that cracking the cedar scales.
I am assuming, that I need to do something to the "pin" before I start so that I have some amount of an upset head. Perhaps I am missing a tool or two to accomplish such things. I was concerned introducing heat anywhere near the scale material for fear of scorching it, or other such damage. I am not a black smith so anything I am doing like this is generally done cold. Am I right in thinking that you want the material to match the bolsters, seemed brass would look funny in a stainless bolster. But also, on a folder, does the pin that holds the blade need to be stainless or otherwise something harder than brass?
FWIW, I am starting with brass liners with already attached bolsters and factory created blades and back-springs. I can redrill the brass, but the back-spring is way harder than my drill bits, especially those in such a small size.
The last concern is that when closing the blade wants to catch the liner. I assume this is due to my poor peening and somehow wracking the mount. Is there any good way to correct this? Or great technique to avoid it in the future?
