- May 24, 2010
Any ideas on how to break the lock-tight on a strider if no soldering gun is available?
Thank you for your time!
Some people put the knife in boiling water. 212f is not enough heat to mess with the blade heat treat.
mmmm....sounds like the easiest way so far, but would the water mess-up the g-10 at all ya think?
Perhaps not the heat treat but if epoxy was used to assist in holding the G-10 you risk losing the seal...
Heat source to the screw and let it migrate to the loc-tite.
Thanks, I'll try it.:thumbup:
Grab your wife's hairdryer. Soldering irons cost around $9-15.
Hair dryer is best. :thumbup:
Also works good on kydex.
Wouldn't only a fixed blade use epoxy to hold the G10 scales in place? I guess that is something to consider but I figured he was talking about a folder.
And for what it is worth, I had zero luck with a hair dryer. I guess if you used it long enough it could get enough heat inside the handle to break the bond but you would probably end up getting the surface hotter than boiling water.
