D2 isn't "carbon" though, it corrodes differently from 1095. Anyway. Sounds like I shouldn't buy this knife, huh? Asking for too much trouble off-hand. That stinks. I really liked it otherwise.It will be tuff
Didn't the Vikings use Magnacut exclusivelyWash it like ya wash your Junk..... Ya'all will be fine.
As Others have said, we have been in the oceans longer than we've had advanced steels.
But if you have to sharpen a D2 edge regualry because corrosion is dulling the edge I would say there are better steels for the job.Forming a patina is your best bet but D2 isn't ideal for that.
People freak out about rust way too much. It would take serious corrosion to nullify a knife. As long as you're sharpening the edge regularly and pulling up new steel you're good to go.
Even if I was cutting food with it, I'd use a silicone spray. One of the ones made for meat cutting blades that is made for this purpose. The type that leave a dry surface, not a thick layer of liquid silicone in a carrier that will then transfer to your food.I would probably silicon spray it. If I wasn't cutting food.
D2 is fairly corrosion resistant. A D2 knife would have to be sitting idle for long periods of time with no oil, grease, wax or other protection to degrade the edge like that significantly between usage.But if you have to sharpen a D2 edge regualry because corrosion is dulling the edge I would say there are better steels for the job.
