How to carry
Just took delivery of my first Strider, an EBL-S. Thanks Striderguys :)
So now, how/where do I carry it? I have a concealed carry permit and carry (Glock 34/35) strong-side in a Braveheart IWB, mags on support-side.
Any suggestions?
Thanks :cool:
Look into getting a custom kydex mag/knife holster made for your support side. That way you could use the knife with your support hand if someone ever tries to grab you gun from your holster. You might be able to have a kydex mag carrier made that will screw on to the holes of the supplied sheath. Might save you some money. Good luck, Reagan
Thanks, Reagan. That's basically how I'm carrying it now, with the sheath between my belt and waistband, near the middle of my back.
I'm going to get the HT, or custom HT, with kydex, and want to do the same carry with my 1911 mag (I carry a Springfield Champion 1911 off duty, and a Glock 22 on duty). It should work well. I plan on wearing the HT in my vest strap on my support side under my uniform while on duty. Reagan
The sheath provided by Strider works well. Set it up for cross draw, this will allow left handed reverse grip. You will also be able to sit comfortably. Clamp the Tek-Lok after the first belt loop on the left with the blade in the edge down horizontal position.
Hammerhead2, does this position the EBL-S horizontally over the left front pocket? If so, do you have a recommendation for a concealed carry?
Thanks.
Yes it does, I believe Strider makes an IWB version sheath. Last one I got a look at seemed to have a belt loop where the Tek-Lok would normally be.
