I have recently devoloped a surefire way to change the clip pos. of a tip down only knife, such as alot of cheaper knives, and some higher end knives like the spyderco military and para military. For me, it is a smith and wesson folder, that I wanted to try this and a couple otther mods on. Anyways, here goes!
Materials:
epoxy,(I use devcon 2 ton)
super glue
knife, with clip and screws.
drill with bit close to the size of clip screws.
sand paper
Instructions:
1. Remove the clip from its current pos. Then put the screws away. Next, super glue the clip in the pos. that you want it be in when finished.
2. Now, using the clip as a guide, drill out the handle material, till the screws will go all the way in.
3. Now simply pull the clip up to break the super glue bond.
4. Next, using another knife or sandpaper, you may need to scrape the superglue off the clip or handle material.
5. Now using low grit sandpaper, roughen up the clip and handle where the clip will be.
6. Now taking a bit of superglue, glue the screws to the clip, so the are attached to the clip.
7. Now mix the epoxy, spread a bit on the underside of the clip, around the threads of the screws, and put a bit in you new holes.
8. Lastly, insert the clip with screws in it, into the holes we drilled earlier. Now put pressure on it for about 30 sec. then clean up the excess epoxy to make it purdy.
Materials:
super glue
sand paper
Instructions:
