Hi,
Im new here. I dont have many knives, and they are all pretty inexpensive. I have 12. Im not a huge knife guy, and i dont know the terms well. Sorry for long post.
I got a Ruike 108 a week ago, and the detent on it seems to be a problem for me. I have no problems with other flippers.
When I use the flipper, i have to push it hard. And when it opens, it snaps open very fast and the frame lock gets sticky.
I tried to loosen the pivot and it does not fix this. All it did was give blade play, snap open even faster, and/or blade touching the liner when closed... but still requiring same amount of force to flip open. So i think either detent ball too deep in detent hole, or framelock is pushing into tang harder than it should.
So i disassemble, maybe i can try to “bend” the frame lock backwards maybe... but the framelock has the useless “beta plus lock” thing attached with a free spinning screw on it, and I cant remove the beta lock. So I cant really change the pressure of frame lock onto blade.. also a bit rusty and many burrs inside the knife.
How do i fix this? Do i grind the detent ball or dremel the detent hole to be a bit softer? Im just about ready to just return this and not buy Ruike again. The quaility seems much inferior than the cheaper Ontario Rat 1 and 2. Sure they use nicer steel, but when I disassemble it, it just seems cheaper than it is. The cage ball bearing is cage in plastic, not steel. They balls ride on steel liners that seem not perfectly smooth, and some screws just free spin, and cant unscrew.
I maybe wrong but to me it feels like they went on a checklist of all the cool features like:
good steel? Check
ball bearings? Check
nice packaging.. check!
Cool looking??? Check
Low weight? Check
Ergonomics... well we cant really show ergonomics so forget it.
Now just put it together and sell it cheap. Dont care how it is inside as long as the features exist.
I much more like the the cheaper Ontario Rats because they are build well.. even though they look worse aesthtically, made with cheaper materials, with teflon+bronze washers and comes in a crappy box.
Sorry for long post. Very frustrated because i really wanted to like it because.. it was cheap and made with good stuff.. but disappoined when i disassemble the knife
good steel? Check
Low weight? Check
