I have a question which MODiFiEDZ may be able to answer.
Can anodising be restored by re-anodising to the same colour?
Can the colour be changed, for instance can the lower voltage bronze be changed to the higher voltage blue?
Yes I do it quite often to pocket clips that are worn or faded. I usually touch up faded blue Hinderer clips at 24-26 volts & for bronze I touch up with 10-12 volts.
Yes you can turn a bronze clip into a blue clip by turning up the voltage & you can't turn a blue clip into bronze at the lower voltage unless you remove the anodizing mechanically or chemically first.
