I don't think that 110 has dyminwood. That 110 has a square frame and those are called the 2 dot 110, because there are 2 dots on the stamp.
(I maybe wrong) But those have real, solid macassar ebony. I would clean it with WD-40 on a cloth and elbow grease. Then use a metal polish
like Flitz to shine the frame. DM
I have two old 110’s that I’ve used brake cleaner on. Then oil it all with mineral oil.
Keep in mind Buck has an awesome spa service. They will make that knife look new. For a very reasonable price.
I’d send it to them for it’s initial cleaning/ preservation.
Agree with this. I have both a 2-dot Buck 112 and a 4-dot 112. Both with solid ebony handles, and not the stabilized, laminated wood of later Buck models. If OP's is a 3-dot as described, I'd assume it likely has the solid wood handles as well.
Something like the WD-40, or mineral oil, or the 'lemon oil' (almost entirely mineral oil with the lemon additive) would work OK, used on a rag. I've occasionally used so-called 'lemon oil' on mine, and it's fine. And the metal polish, like Flitz or Simichrome or Brasso, would handle the tarnished brass.
A 3 dot model would put it at 1980-81. This is still solid macassar ebony. Not a laminate and the blade is 440C steel. Yes, Pledge furniture cleaner would work too with a worn toothbrush. You'll need to get it in the blade well and pivot. So, plan on using plenty of elbow grease.
At that time frame Buck did a different grind on the blade, a little fuller hollow grind. Still, a good find. Did you get the original sheath? DM
You're welcome.Thanks Wowbanger and Tjstampa.
Good ideas from both of you.
I'm not so much worried about the brass. It's less delicate than the ebony.
You're welcome.
I have a four dot so what do I know. I bought it in about 1981 or '82
