Hey all.
I have a question and I don’t know the proper terminology to use. I’ll try my best to describe what I am asking and hope you can understand my ramblings.
I am curious about that “line” you get after sharpening a knife. Sometimes there isn’t one or it’s so close to the edge that it can’t be identified. Other times you see an area that’s been in contact with the stones and where that contact stops is the “line” I’m talking about. On some knives like my Kabar Marine Corps knife that area is quite large, maybe 1/2 an inch from the actual sharpened edge.
Ok, now that I’ve explained that, I have a question.
I use a basic Lansky system. I’ve sharpened several pocket knives lately with good results. Most all don’t have that “line” cause it’s right at the sharpened edge.
On an old Remington Stockman I was given I got out my Lansky to sharpen all 3 blades. I started with the sheepsfoot blade. After I finished the edge of my knife looked far different than all my other knives. I used the 18 degree hole to sharpen. I ended up with a “line” that’s prolly 3mm or so from the sharpened edge, give or take. It’s plainly visible and it looks far different than everything else I’ve sharpened. When I saw what was happening as I sharpened I had no option other than to finish. It has a nice, sharp edge to it now, but I don’t care much for that “line” being so far from the edge.
I haven’t started on the other 2 blades cause I was afraid I would end up with the same results as the Sheepsfoot.
What did I do wrong? I done everything just like I did in my other knives. I guess I could’ve made a mistake without noticing it. What causes this to happen?
If needed I can try and post a picture for you.
Any help you can give me would be greatly appreciated.
Thank you for your time.
