My first suggestions would be to fill out your profile a bit so we get a little personality from it, and to read the stickies and the thread that was formerly right under yours. (Metal cutting blade on wood band saw?) I know search is not enabled for you, but you can search B.F. well with google and get plenty of threads about cutting blanks, and metal saws/blades.
It's just that I could regurgitate all I know and have read about it, but you'd get more info and internalize it better having searched it out on your own.
I'll say that you want to forget about getting a metal blade for either of the saws you currently own. It can be done, but you have to lower the speed a lot for the bandsaw and the scroll saw is too underpowered/not the right tool for cutting blanks. Get a porta-band and clamp it/adapt it into a vertical saw, make a better table for it. You'll find there is a lot of info about this on B.F.
A good solution is the cheap 4x6 bandsaws from Harbor Freight, Northern Tool, etc. Often you can get one for $200 or even a bit less. Or you can start out with an angle grinder.
