As said above but with some other thoughts, the final drawing (can use CAD)  is a result of building a model, because a drawing can't tell you if it will actually work.
- Draw the knife
- Make a model of it out of wood or aluminum for the blade and handle, with a pivot pin and a blade stop pin, and a backspacer.  Now you can check the ergonomics and adjust the design as needed.
- now what type of opening mechanism do you want and how will that affect the blade shape?  Flipper, thumbstud, opening hole etc.  Tinker until you get something that works well.
- next consider the scales and/or bolsters, to figure out how thick you want the final product to be.
- also relevant to thickness, will you be using washers or bearings at the pivot?  If bearings, will you need to mill recesses for them into the liners? You need to figure this out to know the final dimensions of the blade stop and spacers or backspacer and pivot.
- now consider clip design and placement, since that will impact ergonomics.
- now the heart of the design issue: the lock. The lock is all about precise Geometry. You should figure out everything else first because this is the trickiest part.  Button lock, liner lock, compression lock, frame lock, axis lock, other . . . Each has an impact on the design of the blade tang, whether a stop pin is needed, the minimum handle  thickness necessary, and ergonomics for ease of use. . . . unless it's a slipjoint, in which case it's 3 times more complicated and you'll need to watch at least a dozen hours of YouTube videos!
now make the knife again with the actual blade and liner/handle scale thickness you want, and folder parts like washers/ bearings and pivot and spacers and clips etc.  You will probably end up changing several measurements in the process.
once it is perfect, take it apart and make a drawing of it in CAD with the precise measurements of the final product.  Now you can send it to a maker to have it made!
