How To Dye Scales
Will Power
augustus 88 I really like the look of that 'modified' Amber Bone .
What exactly is that stuff and is it permanent?
Today, it's my latest acquisition GEC No.25 EZ-Open in Antique Amber Barnboard. Can't find anything wrong with it,wonderful small sturdy friend.
Fiebings leather dye. http://cornercobbler.com/FiebingsLeatherDye.html
The Amber bone looked like jigged plastic to me so I had to change the color. The Fiebings dye job on my Texas Jack was done two years ago and it still looks the same after plenty of pocket time and use.
I used Fiebings Cordovan and Tan dyes. The Tan dye looks brown when you put it on and turns a very neutral olive green when you wipe it away(on white or amber bone). Predicting the actual color you're going to get is a bit tough. Practice on a cheap Rough Rider knife first if you're afraid to risk a nice knife. I've successfully altered the color on three Case knives, two GEC, one Bulldog by GEC and one Marbles.
1. Heat water in a mug for one minute(enough water to submerge the knife).
2. Soak the knife in the hot water for about a minute or two. Soaking in hot water seems to open up the pores in the bone so the dye penetrates nicely.
3. Remove the knife from the water and quickly dry off the scales. It should be hot to the touch.
4. Apply the Fiebings dye with a Q-tip and allow to dry for a minute.
5. Wipe away all the excess dye with a soft cotton cloth.
6. Repeat all the steps until you get the desired color.
7. Buff the bone softly with the cotton cloth to make sure that no residual surface dye remains.
8. Use compressed air to blow water out of the nooks, crannies and joints.
9. Oil the knife to avoid rust and lubricate joints.
I've used Rit dye to the same effect. Bone got discolored terribly on my Case large stockman, and now it's cleanly black.
The above posts were moved to "Maintenance" to establish their own thread as per the guidelines of the Traditional Forum...
In the future please either post these queries in the proper forum or take the discussion to email and/or PM. Thanks.
Here's the knife in question. The Texas Jack in the middle started out as Case Amber Jigged Bone.
Thank you very much for the excellent reply, the detail was much appreciated by me .The picture of the end product looks first rate, some CASE Amber Bone is rather pale.
As I live in Europe, I wonder if i can get get the manufacturer to send me some? It is inflammable I suppose ,so probably not,pity.
Can you get Rit dye? Most grocery stores here sell it in the same aisle as the laundry detergent.
