It isn't just hitting an austenitizing temperature, it is also holding that temperature long enough to free up the correct amount of carbon and allow it to diffuse into what will become the martensite. O1 needs a good soak (ideally over ten minutes), D2 needs a soak at over 1800 deg for over half an hour!
One way to evaluate the HT is to take a similar knife of a known good HT and your new knife and subject them to the same tests. Assuming they are similar geometry and sharpened the same, when subjected to the same amount of cuts in the same cardboard, then the same amount of cuts in the same leather, then perhaps hardwood or whatever kinds of use that would be appropriate for the type of knife, you will see which one goes dull faster and by what mechanism.
Now obviously, even a well heat treated 1084 kitchen knife isn't going to hold up as well as a so so S30V blade in something abrasive, nor is a good S30V blade going to maintain as fine an edge popping into a cutting board as even a so so 1084 blade. You have to compare apples to apples.
