For small gaps in yard sale kitchen knives, which I'm going to refinish anyway, I squirt superglue into the gap and sand the handle with fine sandpaper. The wood dust mixes with the superglue and matches fairly well.
Since it's shallow looking.....what about cutting off the face of the handle until it meets the bottom of the gap?
Then round over and sand, as you wish
*Gut feel though the sloppy gap probably goes deeper.
Just a thought, you can apply food grade bees wax to fill the gap and keep food and such out but it does wash out with cleanings and requires reapplications. Ive used this on cutting boards to fill hairline cracks and it works ok.
I would use 2 part epoxy and mix in some fine wood dust of similar color into the epoxy.
Use some tape on the blade, closest to the gap as hardened epoxy can be a pain to remove. Would also use tape around the handle on the sides, so when you pour the Epoxy, it doesn't exude out of the side gaps. A light sanding when the epoxy dries and you would never know the gap existed.
Thank you so muchOne technique that has worked well for me is to tightly pack the gap with sawdust from the same material as the handle scales. Then drip thin viscosity CA glue into the packed sawdust. The glue will wick throughout the sawdust and cement everything together. You may need to apply the CA several times to get a good watertight seal, but the CA-saturated sawdust makes an excellent gap-filler! Hard as glass and watertight.
This is pretty easy to do neatly, pretty easy to clean up.
