- May 31, 2001
I used my Lum ti tanto yesterday to cut ivy vines off an oak tree close to my house. I used the knive hard, but did not abuse it, i.e., no hammering or undue twisting movements were used. The blade had developed considerable blade play be the time I was done, both side to side and front to back, but this didn't worry me, as I figured that the pivot screw had come a bit loose. However, tightening the pivot screw solved the side to side blade movement, but not the front to back blade play. So I carefully disassembled the knife, cleaned it up and, just as carefully, put it back together again. No change. When the blade is open, the locking liner is no longer perfectly tight to the tang; I notice the the liner now travels practically to the other side of the tang, whereas, before, it engaged completely when it was about halfway across the tang. What's the problem? I can't believe that the Lum tanto is so easily damaged. Is there something I'm doing wrong? Before anyone suggests tightening the pivot screw, I should mention that I tried tightening it until it was impossible to open the knife with one hand, without any noticeable effect on the side to side blade movement.
Anybody have any ideas?
