sharp_edge
- Jul 30, 2015
I have a ZT folder with an off-centered blade that is impossible to correct with all the tricks that I could find online. If the knife is not assembled properly, it would also have slight detent rock (i.e., blade up and down movement in closed position). I believe the cause of both is that the steel liner is not flat (I put the liner on multiple flat surfaces to verify this). I do not have special equipment other than multiple doors in my home
Will it work if I stick one end of the liner in the hinge of a door and bend it? Or there might be some better approaches? Thanks in advance.
p.s. It appears KAI's method is to loosen the pivot to "correct" the centering at the cost of introducing side to side blade play, so I do not plan to re-send the knife in for warranty work.
