How to get a sharp tip when using a Spyderco Sharpmaker?
HiPlainsGrifter
I have a Spyderco Sharpmaker with the coarse, medium and fine stones and have never been able to get a really sharp point on any of the knives I sharpen with it. Do you have any tips (pun intended) for sharpening the tips of pointy knives to a factory edge. Thanks, all.
Don't let the knife come off the stones. Do a full stroke, but keep the tip on the stone.
This, but it is often easier said than done. If you get going too fast you will pull the tip off. To counteract that, you will often neglect the tip. Sometimes you have to just focus on the tip and work it as a separate section. I’m no expert, but seems to work for me.
Well one name the knife.
Then two pull the knife down and back till you fell the tip come off the stone.
Best advice I ever got was this, dont sharpen the tip. Sharpen TO the tip.
I was having trouble as you were. I was never getting that pointy tip. Do not sharpen the tip. Sharpen the edge right to the tip not leting the tip slip off the edge of the stone.
When I use the sharpmaker, I start at the tip and go to the heel.
I saw this method a while back, and it works for me.
I use the flat sides of the SM, angle the blade down and only focus on the tip without full strokes of the blade.
The first inch of almost any blade is the most used. Therefore it's generally the dullest part of the blade. Which means it needs more work than the rest. On many blades this means you need to spend a LOT of extra time on that first inch. Including the tip. This is a generalization, but it's more true than not.
If the whole blade is sharp, but it's just the point that's dull, it's time to look at it. Really look at it close. If you have a loupe or magnifying glass, use it. You will probably be surprised by what you see, but seeing the actual *shape* of the dull tip is going to show you what to do. You're probably going to find that the point is bulbous and rounded. To make it pointy again, you have to grind away metal until the point forms two lines or arcs that meet at the *very* tip at a nice sharp intersection.
Depending upon how dull the tip is, this might require a good amount of work. Or only a little. If it needs a lot, you're better off focusing on that area with a real bench stone, and then finishing up with the sharpmaker. If it only needs a little work, then use the sharpmaker. As the guys above have said, don't let the tip come off of the stone. That "skating off" action is one of the ways the tip gets rounded off in the first place! So, as Italian said, sharpen *right up* to the tip, but not past it.
You'll know you've done a good job when the tip of the blade catches your finger prints and digs in, much like a push pin would if you lightly drag your finger across the sharp point. Try this before, during, and after so you can have a gauge of your progress.
Extra time
Loupe (Observation)
Remove roundness to form sharp intersection
Patience
Brian.
One helpful tip I saw on YouTube is to lift the knife as you pull it past the stone. Just slowly pull your elbow up continuously as you move the knife
It helps to slow down your pull. It takes a bit of concentration since we often just go through the motions of down and back, often neglecting the tip.
Those interested may find this video useful:
