- Apr 24, 2009
I recently picked up a case peanut with Tru-sharp blades, and I'm experimenting with a new sharpening process. I flattened a small block of wood to use as a backing, and I've been using black binder clips to hold cut-to-size sandpaper sheets on, as I sharpen using the sandpaper with an edge-trailing motion. I used 60 grit to reprofile (the angle is basically the spine being raised one blade-thickness above the stone), then moved to 100, 150, and 220 to get rid of the 60-grit gouges. From there I moved to 400, 600, 800, 1000, 1500, and 2000 grit sandpaper, and my edge is nice, but I'm looking for the next level. Should I move to a leather strop? If so, what should I load it with, if anything? If not, is there a finer-grit medium I could use, I can't find sandpaper finer than 2k. What about cardboard/loaded cardboard? I really like the cheapness and simplicity of the setup I have, so I'm not looking for suggestions to buy an EdgePro
