- Dec 21, 2006
Guys, I would GREATLY appreciate your help here. I'm about at wits end. I'm trying to do a diff heat treat. On a knife with a 4 inch drop point, I have it sanded to 320, and then sprayed it with carb/choke cleaner, and wiped off with a clean rag. I'm using AP Green #36, which is used by knifemakers everywhere, as my satanite. I tried applying the coat directly to the metal, without a thin wash underneath. Maybe 1/16"+ thick. When it dried, it dried with craks in it, and you could break it off very easily. I've tried applying a thin "wash" across the entire surface of the blade, and then applying the thicker coat along the flats above the edge. EVERY time I do this, no matter what, the clay cracks when dried and falls off relatively easy.
What in the world am I doing wrong? I have tried this over and over and over. I've tried letting it air dry slowly, I've tried putting slight heat to it, medium heat to it, you name it.
The only varaiable my feeble mind can come up with is the water content IN the clay itself. Too much? Not enough? When I apply it, the consistency isn't too watery. Too watery and you can't put it where you want it. Maybe I'm still using TOO much water. Thanks again for your comments and suggestions.
