I remove excess epoxy by using a scraper made from a scrap piece of brass. Brass is softer than steel which prevents scratching metal. Warming up the metal a bit, using hot water will help soften the epoxy aswell.
Also, aircraft paint remover will easily remove any epoxy or epoxy-based finishes, paints, clearcoats, etc. It comes in a blue spray can, available at Wal-Mart in the automotive section for around $10. Works great for lots of stuff.
As said before,acetone will soften it up so you can wipe or scrape it off with a wooden stick. If you've no acetone around, try soaking it in your wife's/girlfriend's nail polish remover. Most of those are mostly acetone.
DO NOT get acetone on any plastic parts. While it may not totally destroy the polymer which usually holds G-10 and carbon fiber together, it's not worth the risk. Also, acetone is an excellent de-greaser, so re-lube the knife ( if it's a folder) after you're done.
