- Oct 26, 2000
What is the best way to grind a tanto blade? I realize this may be a loaded question with many answers, but I've just built my first tanto folder and I'm a little worried about attempting the grind. First off, I can't decide if I should try a chisel grind or make it a hollow grind.
I also can't quite figure out how to deal with the two edges on each side. Should I grind a pass or two on the first bevel then go to the second, then flip the blade and do the same thing on the other side unitl they all are done? Or should I grind the main bevels and then go back and do the leading ones as I would a false edge? ANY advice would be much appreciated!
