Howdy, and welcome to knifemaking!
I am fairly new to knifemaking, having made 2 total, but have worked on several others, with friends and family who have all wanted to make a knife. The only steel I have used is 1095, and here's my experience with it:
it takes several times of heating up 1095 to get optimal hardness. I have had the best results when I heat it up slowly, say, over the course of 20-25 minutes, to non-magnetic temp. I do this, then let it air-cool down to where it can be touched with the hand. Then, I heat it up again, this time over about 15 minutes, to non-magnetic. Again, I will let the knife air cool. I will always heat it a third time, too. If the knife is smaller (1/8" thick steel, less than 4" long blade), then I quench after the third heat cycle. If the knife is larger, being it's thicker than 1/8" or longer than 4", then I'll do more heat cycles.
When quenching 1095, it's imperative tht the quench happen very quickly after taking the knife out of the heat. I check for non-magnetic and, if it's there, I throw the knife back in the heat for about 25 more seconds. Then, I'll take it out and immeditaely quench it in the oil pan, which is placed as closely as possible. Now, let's talk about the quench: per Admiral Steel's website instructions, I have played with water quenches and water-oil combo qhench. And, I've always cracked or broken blades when quenching them in water. From my experience, using water on 1095 is just too rapid of a cool. Instead, I use a vat of hydraulic oil (it's a bit less thick/viscous) that I picked up from Wlamart for a few bucks. I heat it up with an old file that's been soaked in the heat with the knife. Then, I quench the knife.
So, that's how I heat treat 1095 and I've been happy with my results, thus far. I got the multi-heat cycle method from both trial-and-error and reading posts here and at knifeforums.com on how to treat 1095. The key to heating it properly, IMO, is to cycle it slowly, numerous times, before quenching. I've had the best results with this method.
By the way, I don't have a heat-treating oven, so I use an old BBQ grill and a shop-vac that's set to the blower function. I keep the shop-vac regulated, though, via a small pipe system with holes drilled into it, in order to keep the heat evenly dispersed and to keep the knife from heating up too quickly. A hair dryer will wrok, too. It'll take a bit longer but, in the case of 1095, that's actually a good thing.
Good luck and let us know (and see pics of!
) your results. Keep on posting with any other questions you have!
-Trout Tamer
