- Feb 19, 2014
I got my Para 2 recently and wondering how do I go about lubing it (have tuf glide) without disassembling it and voiding the warranty?
Want to know for future reference.Does it require lube at this point? They come from the factory with a similar type of lube, should be ok for a while.
The thing is, I'm not sure how I'd go about doing that. Do I just set the tuf glide tip against the crevice between the scale and "the round blade base" (not sure what that part of the blade is called), squeeze a few drops, and hope it reaches the pivot area?I've never had to disassemble my para2s to lube the pivot area.
I never would have thought of that...I have seen a few posts where a drop of oil was applied and then blown in with compressed air. Sounds like that should work OK if you don't want to dissassemble.
That's how I lube mine and it works great.I have seen a few posts where a drop of oil was applied and then blown in with compressed air. Sounds like that should work OK if you don't want to dissassemble.
