Try washing it with dish washing soap and water. Work the blade good. Rinse it in warm water. Blow it real dry with a compressor or canned air. Then lubricate it. That will almost always get it smooth as silk.
Make sure that the tang of the blade does not have any burs.
With the blade closed, feel along the tang, in the groove between the bolsters, from the locking notch to the locking-bar itself.
If there are any burs or imperfections there you can file them smooth with fine grit sandpaper.
Good luck,
Allen
I did the dishwashing soap and water a bunch of times and it's still a bit gritty. Does a little bit of vaseline work well?
If not, anything else which I might have laying around the house?
Thanks a lot guys.![]()
It's walnut.Allen, what scale material is that?
