OK Here's the deal. On a full tang knife, using stabilized burl, I'd like to peen the pins, but I don't see how it can be done and use epoxy?
Issues: If I epoxy first, then push the pins I'll have epoxy in the holes. If I peen after the epoxy is hard, it'll break up the epoxy around the pin. If I peen the epoxy wet I'll still have epoxy in there and it'll show up or will it? Doesn't that make a mess.
Should I even attempt this without a pin press? Won't hammering on a 416 pin run a huge risk of either splitting the wood before getting consistent peening effect or the odds of stricking the wood is ....
Do you epoxy it up, clamp, remove, clean the pins, wait for it to set, and then peen?
I know some of you do this, and I think it's a great idea. I just don't see how I can pull it off.
Steve
Steve
