How to polish INFI?
I'm very close to having funds for a Boss Jack CG. When I get it I want to strip and polish it. I've researched the stripping part and it seams easy enough, but I haven't found much on polishing INFI. What is the best way to polish INFI to a mirror finish? Thanks.
Pretty much the same way that you would polish any other steel. Start with low grit sandpaper and progrssively move onto higher grit. You will end up using wet/dry sandpaper at the end. If you want to go the extra mile, then you might want to use a polishing paste of some sort, usually found at automotive supply stores.
