Hyesouljah
- Dec 21, 2019
Hi friends, got any tips as to how you keep Damascus from fading? Particularly near the thumb stud. What has worked for you? Or is this just the nature of Damascus?
I think that's the route I'll likely take. Thank you!Have it re-etched when it gets bad, otherwise just enjoy it. Beautiful CGG by the way.
Don't use it is not an option for meDon't use.it is the.only sure fire way.Not to lose the dark etch!!!!! Chris Reeve knives will re etch I think!!
If you're adventurous buy some Ferric chloride n do it yourself.. Just watch Todd Begg's video on YouTube about etching because there are a few things you have to do before dropping said blade in the drink!!!!
Good luck.
I think I might order some renwax and try that, it'll be good to have for my traditionals as well. I am most certainly going to be using this knife. Won't be used hard but it'll get pocket time and be used for sure.That's one sweet UG! Good to see you plan to use it too.I'm kind of in the same boat and balancing on whether to use or not. Gosh dang Chris Reeves are so nice to use though and is what they are meant for so will likely go that route. I was worried about the overall blade fading with food prep from the juices both meat and citrus but form what I gather it is mostly cardboard and such that will show the most wear. As far as the thumb stud area, you could try a little coconut oil or ren wax or maybe even paraffin to provide that slight barrier in between.
As far as re-etching, CRK recommends only once in the blade's lifetime. That isn't very much as weakens the blade supposedly. The simple answer may just be use and then after the blade is really well worn then have it re-etched.
Thanks, I think if push come to shove years down the line I'll send it to CRK and have them do it,Modern damascus basically is two steels pattern-welded together, typcally, one steel is stainless and one is not. The knife maker dip the blade into acid, the stainless steel stays shiny while the non stainless one turns dark, revealling the pattern. The pattern is only on the surface of the blade, so it will wear and fade over time.
Now, understanding how it works, it's fairly simple to do it on your own: just buy some acid and dip the blade in.
But what acid to choose? I'm glad you asked, for the quickest result, people usually use Ferric Chloride, but since this acid etch steel quickly, it will ... etch the steel quickly. Meaning that you could damage the knife if left in for too long. A safer but slower solution (pun intended) is to use Vinegar or Coffee. Depending on the steel, concentration, tempurature, it could take one hour to a day, so no one can really tell you how long it'll take.
Also, nail polish, clean before, clean up after, blah blah
TLDR: you can re-etch damascus ... if you know how.
Too late for that!If you place the knife in a box and lock it away and never use the knife then I am pretty sure that the Damascus will not fade.
Thank you! I actually coated it lightly with mineral oil and cleaned the excess off with a microfiber a few days ago. I just ordered some Renaissance wax as well so I’ll apply a thin coat of that on the blade as well when it arrives.Beautiful knife. With damascus, I've found that putting some high quality
pure mineral oil on the blade, and then spreading it around (carefully)
with a (clean) fingertip. The damascus begins to darken almost
immediately. Wipe off the remaining oil with a microfiber cloth but
leave a bit on the blade as a "sheen"
Then just put the knife somewhere safe, as dust and lint-free as possible.
Not in a sheath, of course,
IME the blade will continue to darken somewhat leaving real nice color
and highlighted etching. Then, oiling or waxing it every few weeks
will maintain the look as it was when you bought it.
Enjoy, and hope you find this info to be useful.
Thank you sir, I just received my ren wax and was wondering if it’s actually food safe or not. This knife is definitely not gna be a user as my other knives but if it’s in my pocket and I need to cut something it’ll definitely do it’s duty.Cool
I think a lot of damascus collectors use that very same
regimen with consistently excellent results.
One thing, though - as amazing a product as Ren Wax is, one thing it is NOT
is food safe. In other words, it isn't food safe. That chemical smell alone
would get you thinking about that,
I use a couple of food safe waxes on my damascus knives which
I plan to use for food prep,
Amazon.com: Caron & Doucet - Natural Wood Conditioning Vegan Wax Finish - 100% Plant Based Wood Conditioning and Polishing Wax Finish - Orange Scented - Suitable for Natural Wood Furniture. (3.5oz) : Health & Household
Amazon.com: Caron & Doucet - Natural Wood Conditioning Vegan Wax Finish - 100% Plant Based Wood Conditioning and Polishing Wax Finish - Orange Scented - Suitable for Natural Wood Furniture. (3.5oz) : Health & Householdwww.amazon.com
Amazon.com: WALRUS OIL - Wood Wax, 3 oz Can, FDA Food-Safe, Cutting Board Wax and Board Cream : Health & Household
Amazon.com: WALRUS OIL - Wood Wax, 3 oz Can, FDA Food-Safe, Cutting Board Wax and Board Cream : Health & Householdwww.amazon.com
Over the years, I've found its good to switch off from mineral oil to wax and then back.'
Not sure I can fully articulate the reason, though.
Anyway, enjoy your damascus!
Some advice - with ren wax, a very little goes a very long way. I barely glide the cloth over the wax in the bottle, and sometimes that is too much. Great stuff Renaissance Wax .Thank you sir, I just received my ren wax and was wondering if it’s actually food safe or not. This knife is definitely not gna be a user as my other knives but if it’s in my pocket and I need to cut something it’ll definitely do it’s duty.
I usually use my knives for food prep when it’s on trips with me so I’ll just have to be careful with the ren wax.
Definitely going to apply some to my traditional knives with wood.
