So... I did a little work on my ZT 0566, ( http://www.bladeforums.com/forums/s...proved-pivot-amp-more?p=13329899#post13329899 ), and after re-assembly, the blade was too close to the frame-lock side for my liking. Not rubbing, but being a right-hand thumb stud opener for me, I never wanted it to even come close, after eventual bearing wear or whatever. I wanted it biased toward the G10 (actually now CF) side. I've only seen one youtube vid on how you might try to correct, but loosening all the screws, putting the blade at 90 degrees, or simply wedging with paper, and then re-tightening, didn't seem the best way to correct (IMO).. I think the paper wedge MAY actually help a little, in moving the pivot axis to a slightly different angle, but I think what I've shown here in the pics will have an even better influence in correcting that blade centering, should yours need it. Loosen the pivot, and ALL the handle/scale screws. Use your $5.00 clamp from harbor freight, and clamp it as shown. (opposite, of course, if you need to go the other way. DON'T apply 50 pounds of force, and break your knife
. That would suck. Just enough pressure to re-orient the parts a little and move the blade. If it helps, but not quite as far as you need, start over, loosen the screws MORE, tap and wiggle the blade and handles to re-seat the screw heads in a better position, and then clamp and snug the screws again. I'm pretty sure this method should correct most centering issues, short of a bent blade, or something mechanically not flat and parallel, or the pivot axis just not being 90 degrees to the handle. Try the paper wedge too... Anyway... worked great for me first shot, and I've never seen this posted before, so maybe I helped somebody out :thumbup: good luck
