this is what im going for
So all i need to know if I can still do it with mustard or vinegar even though its polished up so much.
Yes, you can. Whichever method you use (mustard, vinegar, combination of the two, etc.) will affect how it looks in the end. Almost infinite possibilities in how it'll turn out. The 'dipping' method I mentioned earlier generally leaves a more even patina. The mustard method is often used to apply unique patterns, if you want to do that, by spreading or applying mustard accordingly.
The high polish, as I mentioned earlier, will tend to resist oxidation a little bit (this is how a polished finish can help minimize rust as well), and therefore slow it down. It'll still oxidize though, and a 'hot' application accelerates it. If you want to, you could scuff up the polish before starting, using some Scotch-Brite or medium/high-grit sandpaper. The rougher finish tends to give more surface area for oxide to form, and therefore will speed it up and/or leave a somewhat darker or flatter (less glossy) finish. If you're still wanting an even-looking finish, it's very important to make sure the scuff/sanding pattern is very uniform; if it isn't, you'll likely get blotchy results.
Nice thing is, if you don't like how the final result looks, it can all be polished off with some Flitz or Simichrome paste and some elbow grease, and you can start over if you want to. Not that much risk in experimenting, within reason, assuming more harsh acids/etchants aren't used (ferric chloride, for example).
David
