How to remove blade coating (TUTORIAL!)
Ok so this question seems to pop up a bit and I know there’s 80000 threads on it but meh, was going to strip the coating anyway and you may as well come along for the (mildly exiting) ride...
THINGS YOU NEED:
-Newspaper or something to protect the ground of your going this inside your house or garage.
-Safety glasses
-Paint stripper (No shit :rolleyes:)
-Something to scrape of the coating (I use this old USAF copy knife…Stanley blade, paint scraper, anything will work…I find Stanley blades gum up with all the coating so that’s why I like the knife).
-Item to be stripped (Duh!)
-Rough sandpaper (Optional)
-Wire brush (If you wanna get into all the small holes and have a nice coating free finish you’ll need this, much harder to scrape off every bit with just the knife).
-Gloves (Decent heavy gloves, I find the stripper just eats though the disposable ones).
005 by CamH_16, on Flickr
OPTIONAL STEP: Give the coating a good scratch, I find it breaks up the surface and allows the stripper to eat its way in faster).
008 by CamH_16, on Flickr
SPRAY ON THE STRIPPER!
014 by CamH_16, on Flickr
010 by CamH_16, on Flickr
Like I said with the sandpaper, about 10 seconds in you can already peel of the coating if you’re that impatient…I wait about 1 minute…Best to wait about 20 I think?
020 by CamH_16, on Flickr
After a while begin scraping it off, you’ll most likely get some lines left behind so just use the wire brush and clean it all up.
023 by CamH_16, on Flickr
027 by CamH_16, on Flickr
When your happy with the results just wash it off… Obviously from here, blue, patina, polish, Clich or whatever it is you wanna do to the blade can be done now. There DONE! Not amazing but hopefully this helps someone out. If you’ve got your own way or any tips just post them below…
033 by CamH_16, on Flickr
Later :).
Thanks for posting. I just stripped the blade portion of my BK15 and will be stripping my 2 and 17 here real soon using spray on Jasso. I left the finish on the handle so I didn't have to worry about rust but didn't like the rough finish on the blade.
Charlie
Bravo! I'm sure everyone will enjoy this. :)
Erd
Thanks Erd!
Charlie
I think 220 or 320 grit sandpaper will leave a nice satin finish on the blade if you dont like the rough factory look. Good choice on keeping the coating on under the scales...Especially if your using removable scales, for permernant ones epoxy should hopefully hold off any liquid.
