- Mar 9, 2014
My first post. Gained a lot of knowledge and for that I am thankful for all that contribute. I have a question. Use mostly CPM154 and CPM S35VN. I do start to finish on my own including heat treat in which I use stainless steel foil to wrap the blades. Before I heat treat, blades are about 90% complete. Following heat treat, I finish up the grinds (which are usually sabre) but my problem is removing the coloration from heat treat on the non grind part of the blade. I currently use a magnetic holder with the knife against the platen with a 220 grid belt--somewhat effective but one flinch and a lot of work is down the drain plus loads up belts FAST. I have tried 220 paper by hand but very time consuming. I am thinking that much more learned than I must have a better method the get the non grind part of the blade ready for final finish. Thank you in advance!!!
Jeff Denton
www.facebook.com/jeffdentonknives
Jeff Denton
