How to safely remove the screw without breaking it
Brothers, do you have any ways to remove the screws without breaking the screws, especially the screws made of color and Mikata? There is usually some rust in the 3V handle, I want to disassemble it for maintenance and cleaning, but there seems to be screw glue How to disassemble it without destroying the screw and Mikata patch, do you have any good methods? All I can think of is blowing with a heat gun, but I'm not sure if that will ruin the nice colors on the Mikata and the screws, so I haven't experimented yet, if you guys have any good ways to do it please let me know thank you!
I used some heat to breakdown the adhesive. Try using a small amount of heat from a hair dryer or even lightly with a torch.
Oh, thank you, bro
One side is red loctite. Use two quality Torx bits.
Thank you bro I just bought the wiha,I will try it
Thanks for the reminder Play obviously didn't see this comment haha
Oh, thank you, bro
Heat should not be required
Two torx bits. One on each side. When you unscrew them opposite each other, the torx bit on the blue lock tight side will come loose. The red loctite side will stay attached. This is what you want. Then you push the pin out. Sometimes it needs to be tapped.
Thank you very much! This design is great
